210
Unable to have column edit as Combo (dropdown mode) when using MVC Helper
When I use the example for the jquery grid the combo dropdown works on the editing of a column however when I use the MVC helper it does not and instead when editing the column it renders as a textbox.
I've tried running both examples side by side in the same web page to ensure it wasn't something to do with the script loading of jquery/infragistics or the type differences but still it only works on the jQuery version.
Here is how I'm instantiating my mvc grid.
<div class="row col-sm-12 col-lg-12 col-md-12">
    @(Html.Infragistics()
        .Grid(Model.UserVms)
        .ID("igGrid")
        .Width("100%")
        .AutoGenerateColumns(false)
        .AutoCommit(true)
        .PrimaryKey("UserName")
        .UpdateUrl(Url.Action("UsersSaveData", "UsersManagement"))
        .AggregateTransactions(true)
.Columns(column =>
column.For(x => x.UserName).HeaderText("Username");
column.For(x => x.Email).HeaderText("Email");
column.For(x => x.PostCode).HeaderText("Postcode");
column.For(x => x.Gender).HeaderText("Gender").DataType("number").FormatterFunction("formatGenderColumn");
column.Unbound("Delete").HeaderText("").Formula("getDeleteBtnTemplate").UpdateMode(UnboundValuesUpdateMode.Auto);
.Features(f =>
f.Paging()
.PageSize(15)
.ShowPageSizeDropDown(false);
f.Updating().ColumnSettings(cs =>
cs.ColumnSetting().ColumnKey("UserName").Required(true).TextEditorOptions(o => o.ValidatorOptions(vo => vo.LengthRange(4)));
cs.ColumnSetting().ColumnKey("Delete").ReadOnly(true);
cs.ColumnSetting()
.ColumnKey("Gender")
.EditorType(ColumnEditorType.Combo)
.ComboEditorOptions(wrapper => wrapper
.Mode(ComboMode.DropDown)
.DataSource(Model.Genders)
.ValueKey("Key")
.TextKey("Value"));
f.Updating()
.EditMode(GridEditMode.Cell)
.EnableAddRow(true)
.EnableDeleteRow(false)
.DeleteRowLabel("Delete");
.DataBind()
.Render())
</div>
When inspecting the generated jQuery from this, it seems to be setting everything as is in the following jsfiddle jQuery example - jsfiddle.net/.../
Here is the jQuery output - http://pastebin.com/RmvzqSkR
Parents Reply Children
No Data
