Note:-in the highlighted part I want the header business group
I have used this for grouping
<igDP:FieldLayout.SortedFields>
<igDP:FieldSortDescription FieldName="BusinessGroupName" Direction="Ascending" IsGroupBy="True" ></igDP:FieldSortDescription>
<igDP:FieldSortDescription FieldName="BusinessUnitName" Direction="Ascending" IsGroupBy="True"></igDP:FieldSortDescription>
</igDP:FieldLayout.SortedFields>
I have hidden the columns in the actual field layout since I did not want eh column name repeated.
<igDP:FieldLayout.Fields>
<igDP:Field Name="BusinessGroupName" Label="Business Group" Visibility="Collapsed">
</igDP:Field>
<igDP:Field Name="BusinessUnitName" Label="Business Unit" Visibility="Collapsed"
Settings="{StaticResource Grid_ReadOnlyColumn_String_wTooltip}" />
<igDP:UnboundField BindingPath="Relationship.RelationshipName" Label="Relationship Name" Name="RelationshipName" >
<igDP:UnboundField.Settings>
<igDP:FieldSettings CellWidth="280" />
</igDP:UnboundField.Settings>
</igDP:UnboundField>
<igDP:Field Name="LegalExposure" Label="Cust Commit" Visibility="Visible"
Converter="{x:Static framework:AdvancedNumberConverter.Instance}"
ConverterParameter="{framework:AdvancedNumberConverterOptions NumberDiviser=1000, EndNumberFormat=C0}"
</igDP:FieldLayout.Fields>
Hello Ramya,
Can you please clarify when and where you wish to display field header's when the data grid is grouped/ungrouped? You can specify where field headers will appear in various situations in case you need to. The HeaderPlacement settings in the FieldLayoutSettings can help you manipulate the location of the headers.
eg.
<igDP:XamDataGrid x:Name="XamDataGrid1"> <!--#BEGIN SNIPPET#--> <igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings HeaderPlacement="OnTopOnly" HeaderPlacementInGroupBy="OnTopOnly" /> </igDP:XamDataGrid.FieldLayoutSettings> <!--#END SNIPPET#--> </igDP:XamDataGrid>
Let me know if you have any questions regarding this matter. For more details please visit our online help:http://www.infragistics.com/samples/wpf/data-grid/header-placement
Hi Michael,
I want the header in top but I don't want the row with data like attached
Ramya
The XamDataGrid does not support the removal of individual groupby field headers per record island and/or having them appear once at the top only once. They appear always and cannot be changed.
You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
There are many benefits to submitting a product idea:
Direct communication with our product management team regarding your product idea.Notifications whenever new information regarding your idea becomes available.Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.Allow you to shape the future of our products by requesting new controls and products altogether.You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible.
- Explain the context in which a feature would be used, why it is needed, why it can't be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
- Include a link to this thread in your idea so product management will be able to look back at this case.
The Product Idea site puts you in the driver's seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
You may be interested in the XamTreeGrid, but obviously it's not designed with groupby in mind.
Thank you for contacting Infragistics.
Sincerely,
Michael Di FilippoAssociate Developer
