Looking at this example:
https://www.infragistics.com/samples/silverlight/pivot-grid/#/flatdatasource-xaml
When I leave only one measure in there it does not diplay it on top of the columns...? is it possible for keep the measure as the header on top of the columns even if it is the only measure...
If you removed all of the measures and just left with "Amount of sale"..it does not appear in the column header but when you have "Unit Sold" as well in there. It displays both..??
Is it possible to display 1 too...sorry repeating,,,making sure you understnd this.
From esthetic point of view you are right, but what will happen if ‘Seller’ dimension was in column? Then Units sold should be in rows. We leave the header empty because there is not selected dimension for columns. The headers are predicted for dimensions only.
At this point there is not workaround. If you want you can contact our support department and submit feature request.
Regards
Todor
Let me know if you would like me to create a feature request and I’ll handle it for you.
Yes. That would be great to have that feature. Do I have to formally make a request, How do we do that ?
I will create the feature request for you.
I have created a case for you and will contact you directly thru that case concerning your feature request.
This was 5 years ago.
We have the same request from our clients and its rather a good request for reporting.
Has this feature been implemented yet?
