I have a requirement for hiding the grid records which have following conditions:
- ns_of_items is 0 AND tk_name have 'item name' in it and code I am trying to implement is as follows:
$(grid_id).igGridFiltering('filter', ([ { fieldName: "ns_of_items", expr: 0, cond: "doesNotEqual", logic: 'AND' }, { fieldName: "tk_name", expr: 'item name', cond: "doesNotContain", logic: 'AND' }, ]));
The problem is, this logic removes any record which has 'ns_of_items' as 0 for any records. Ignoring if the tk_name has 'item name' or not.
Any help is appreciated.
Hello sarojanand,
Did you try to use "OR" logic for the second filtering expression, like for instance:
$(grid_id).igGridFiltering('filter', ([ { fieldName: "ns_of_items", expr: 0, cond: "doesNotEqual", logic: 'AND' }, { fieldName: "tk_name", expr: 'item name', cond: "doesNotContain", logic: 'OR' }, ])); ?
When you use "AND-AND" logic to filter your records, then the filtering widget passes through all the records and looks for every single record if it fits both ns_of_items!==0 and tk_name!=="item name" conditions. In your case there might not be any records that satisfy this condition.
Please try AND-OR logic instead and let me know if it helps you resolving your issue.
Regards,Tsanna
