85
search full text in hierarchicalgrid
Hi everybody,
has anyone a good example for a search-box function in hierachical grid? I have one parent-band and one child-band.
At the end, my code crashes a the bold marked code "row.cells", see below.
                //Events:
                $("#btnSearch").igButton({ labelText: $("#btnSearch").val() }).click(function () {
                    findRows($("#txtSearch").val());
                $("#btnClear").igButton({ labelText: $("#btnClear").val() }).click(function () {
                    clearSearch();
                function findRows(searchValue) {
                    parentGrid = $("#WebHierarchicalDataGrid1").igHierarchicalGrid("rootWidget");
                    if ($.trim(searchValue).length > 0) {
                        for (var rowIndex = 0; rowIndex < allParentRows.length; rowIndex++) {
                            if (searchCells(allParentRows[rowIndex], searchValue)) {
                                if (!$("#hierarchicalGrid").igHierarchicalGrid("expanded", allParentRows[rowIndex])) {
                                    $("#hierarchicalGrid").igHierarchicalGrid("expand", allParentRows[rowIndex]);
                            } else {
                                if ($("#hierarchicalGrid").igHierarchicalGrid("expanded", allParentRows[rowIndex])) {
                                    $("#hierarchicalGrid").igHierarchicalGrid("collapse", allParentRows[rowIndex]);
                    } else {
                        clearSearch();
                function searchCells(row, searchCellValue) {
                    for (var cellIndex = 1; cellIndex < row.cells.length; cellIndex++) {
                        var cellValue = " " + $(row.cells[cellIndex]).html() + " ";
                        if (cellValue.toLowerCase().indexOf(searchCellValue.toLowerCase()) >= 0) {
                            return true;
                    return false;
                function clearSearch() {
                        $("#inpSearch").val("");
Parents
No Data
Reply
  • 5513
    Thank you for using Infragistics forums!
    From what I can see row is a member of allParentRows which is not defined in the code you pasted. My best guess is that allParentRows is actually a jQuery object and the code doesn't iterate it correctly.
    Try changing
    to
    if (searchCells(allParentRows.eq(rowIndex), searchValue)) {
    If you could provide me with the code responsible for assigning the value for allParentRows, I should be able to help further.
    Please, let me know if you have any other questions or concerns!
    Best regards,
    Stamen Stoychev
Children
