Hi.
I am using CategoryXAxis bound to DateTime component of my series. My chart has few data points (10 - 15). The problem I am facing is that the X axis doesn't show all the x-axis labels for my series, even though the chart width can easily fit the labels. This problem exists with all of the three series I tried: LineSeries, SplineSeries and ColumnSeries
Is there a way to force display all the X axis categories.
Thanks.
Hello Sandip,
When the XamDataChart loads, it will determine a 'logical interval' for the chart labels based upon the number of labels and the chart's size. This can be overridden by setting the Interval property on your CategoryXAxis, as this property determines the frequency of when the labels are drawn. If you set this property to 1, you should see all of your labels drawn, as this will essentially set a frequency of "every category."
Sincerely,AndrewAssociate Developer
Hi Andrew.
Thanks. That works, I will mark you answer as verified solution. Is there a feature to force XAxis labels which are important, even though they might get skipped in a normal rendering of the XamDataChart because of this 'logical interval'?
Sandip
