80
ToolTip for template column
I am using the ToolTipContentTemplate to show the tooltip on one of the XAMGRID template column.The XAML snippet for the same is shown below:
<Ig:TemplateColumn.ToolTipContentTemplate>
<DataTemplate>
              <StackPanel>
                     <TextBlock Text="{Binding SomeField}" />
              </StackPanel>
       </DataTemplate>
</Ig:TemplateColumn.ToolTipContentTemplate>
This template column has a ItemTemplate (TextBlock)  and a EditorTemplate (Control derived from TextBox).
With the above code the tooltip appears as expected but one of my requirement is to conditionally remove the tooltip for the cells at runtime. The tooltip should not be visible even if it is in edit mode.
I would appreciate, if you could please provide some guidance for the implementation of the above requirement.
Samson Tuscano
Parents Reply Children
No Data
