Hello support,
I have some problems to set a fixed width to a column in igPivotGrid.In your documentation it says we have an option to set the default row and header width.
This is my configuration object:
As you can see in image 1, we do not have any data when the page finish load, and the first column, have width 250px like the configuration.
When we load the data with more then one measures selected, the grid ignore the column default width (see image 2).
What I should do to force the default column width?
Hello Helder,
The "width" option should not be under "gridOptions". Try removing it or moving it under the main pivot grid options. The same is for the height.
Best regards,Martin PavlovInfragistics, Inc.
Hello Martin,
I tried your solution, but it still the same, nothing change in the header column of the table. The header still not respect the default width configuration.
I only want define the default width of the header and the default width of the columns at the same time. But aparently, if I have the default width of the columns configured, the pivot grid ignore the default width of the header.
I'm using the version 16.2.20162.1035 if it help you.
Best regards,
Helder Cunha
