65
Webdatagrid default width not working when column fixing enabled
Dear Team,
We’re facing an issue with  Infragistics webdatagrid (V 14.2)  Default column width property. When ever we Switch on the Feature of column Fixing , the Default width is not being respected properly.
Please find attached a sample with both grids ( one with column Fixing enabled and another without) to demonstrate the issue. Can you please look into it and advise us if we are missing anything or is it an issue with webdatagrid itself.
Prashanth
IGDatagridColumnFixing.zip
Parents
  • 25665
    Hello Prashanth,
    I have been unable to run your sample, as there errors when building and it seems to be missing dependencies. In the future, I recommend sending WebSites instead of solutions as they transfer better. I created my won sample with the version you are using and I am unable to reproduce the behavior. Please run my sample and let me know what you see. Would you please modify my sample to reproduce or send an isolated sample that is more simplified than your current sample?
    WDG_ColumnFixing.zip
Reply Children
