40
can't close the valuelist in the cell of a UltraGrid
I have scenario where I'm displaying a valuelist (as a dropdownlist) in the cell of the UltraGrid. The valuelist has some values and when user selects any value I show him a message box to confirm. Once the user confirms by pressing OK the Valuelist doesn't close. I'm attaching the code. So could you please let me know how do I close the Valulist.
Private Sub ugEMwithP2_ValueListClick(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinGrid.CellEventArgs) Handles ugEMwithP2.CellListSelect
Dim l_objDataMgr As New DWSDataManager.DataManager
Dim l_intDeedsAppIdNo As Integer = ugEMwithP2.ActiveRow.Cells("id").Value
Dim l_intCertIdNo As Integer = ugEMwithP2.ActiveRow.Cells("cert_idno").Value
Dim l_intAssignToValue As Integer = CType(ugEMwithP2.ActiveRow.Cells("Assign To").ValueListResolved, Infragistics.Win.ValueList).SelectedItem.DataValue
Dim l_intAssignToText As String = CType(ugEMwithP2.ActiveRow.Cells("Assign To").ValueListResolved, Infragistics.Win.ValueList).SelectedItem.DisplayText
If e.Cell.Column.Header.Caption = "Assign To" Then
If MsgBox("Are you sure you want to assign this item from the work list to " & l_intAssignToText & " ?", MsgBoxStyle.YesNo, "Assign this item From Worklist?") = MsgBoxResult.Yes Then
l_objDataMgr.EMwithP2AssignUsers(1, l_intDeedsAppIdNo, l_intCertIdNo, l_intAssignToValue)
Exit Sub
End If
End If
End Sub
Parents Reply Children
No Data
