220
Xam Numeric Editor looses focus
Hi Team,
I have an issue with xam numeric editor loosing focus which has a precision of two.When i enter the first digit the focus is lost.Not waiting for the second to enter.
Any help would be greatly appreciated.
Xaml Code:
<igEditors:XamNumericEditor HorizontalAlignment="Right" Grid.Column="3" InvalidValueBehavior="RevertValue"
        MinHeight="20" Height="25" Margin="3,0,3,0" IsAlwaysInEditMode="True" IsKeyboardFocusWithinChanged="UIElement_OnIsKeyboardFocusWithinChanged">
        <igEditors:XamNumericEditor.Style>
        <Style TargetType="{x:Type igEditors:XamNumericEditor}" BasedOn="{StaticResource XamMaskedEditorBaseStyle}">
        <Setter Property="Mask" Value="{}{double:2.0}"></Setter>
        <Setter Property="ValueType" Value="{x:Type sys:Decimal}"></Setter>
        <Setter Property="MinWidth" Value="25"></Setter>
        <Setter Property="IsAlwaysInEditMode" Value="True"></Setter>
        <Setter Property="Tag" Value="{Binding ElementName=UcTelemetryWorkspace}"></Setter>
        <Style.Triggers>
        <DataTrigger Binding="{Binding IsChecked, ElementName=RbDataDensity}" Value="True">
        <Setter Property="Mask" Value="{}{double:4.1}"></Setter>
        <Setter Property="Text" Value="{Binding Data.ExpectedDataDensity,UpdateSourceTrigger=PropertyChanged}" ></Setter>
        <Setter Property="MinWidth" Value="35"></Setter>
        <Setter Property="Width" Value="50"></Setter>
        </DataTrigger>
        <DataTrigger Binding="{Binding IsChecked, ElementName=RbRepeats}" Value="True">
        <Setter Property="Text" Value="{Binding Data.RepeatData,UpdateSourceTrigger=PropertyChanged}" ></Setter>
        </DataTrigger>
        </Style.Triggers>
        </Style>
        </igEditors:XamNumericEditor.Style>
        <i:Interaction.Triggers>
        <i:EventTrigger EventName="KeyUp" >
        <i:InvokeCommandAction    Command="{x:Static controller:JobConfigurationCreatorController.RefreshReportGraphCommand}"  CommandParameter="{Binding ElementName=UcTelemetryWorkspace}"/>
        </i:EventTrigger>
        </i:Interaction.Triggers>
        <igEditors:XamNumericEditor.ValueConstraint>
        <igEditors:ValueConstraint   MinInclusive="1" MaxInclusive="99"></igEditors:ValueConstraint>
        </igEditors:XamNumericEditor.ValueConstraint>
        </igEditors:XamNumericEditor>
Parents
  • 220
    Hi Team,
    Xaml Code:
    </Setter>
    </Setter>
     <Style.Triggers>
    </Setter>
    </Setter>
    </Setter>
    </Setter>
     </DataTrigger>
    Value="True">
    </Setter>
       </DataTrigger>
    </Style.Triggers>
       </Style>
    </i:EventTrigger>
Reply Children
