I am using TestAutomation_WinForms_MicroFocus_20202 with UFT 12.05 and 14.01, not able to identify the object on window base application
Not able to identify the TAB and file menu.
Earlier to this I was using TestAdvantage_WinForms_HP_20092 and UDT 12.05, in that able to work with tab and file menu correctly. Now when I am try to use same script using TestAutomation_WinForms_MicroFocus_20202 with UFT 12.05 and 14.01, it not identify the object.
Please help to resolve the issue.
Thanks and Regards,
Kamlesh
Hello and thank you for contacting Infragistics. Please make sure the Windows Forms Infragistics tools are also updated to 20.2. Test Advantage is not backwards compatible. It's only compatible with the version of tools within the app your testing against is the same. So if your app is still using 2009.2 you must continue using Test Advantage 2009.2
Hi Michael,
When I am using using Test Advantage 2009.2 getting below error-
Could not load file or assembly 'Infragistics2.Win.UltraWinToolbars.v9.2, Version=9.2.20092.1003, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
Is this question in regards to the UltraToolbarsManager? In your first response you had mentioned 2009 was working as expected.
Keep in mind you can only have one version of Test Advantage in-use at a time. If you installed 2020.2 Test Advantage then it's possible that is now the default version and as a result 2009.2 will no longer work without re-enabling it.
The Version Utility is located in Program Files:eg.C:\Program Files (x86)\Infragistics\2009.2\WinForms TestAdvantage (HP)\Version Utility
To verify your installations are working as expected I would begin testing our installed samples that ship with Test Advantage. They're located here: there you will find a Toolbars exe.
eg.C:\Users\Public\Documents\Infragistics\2009.2\WinForms TestAdvantage (HP)\Samples\CLR2.0\Bin
First, make sure the UFT is closed, use the Version Utility to select the desired version of Test Advantage and run the sample's exe. Then you can run a new Record script and interact with the sample.
Let me know if you cannot record/replay against that sample. This will give us an idea if your installation is setup properly.
