Hi Team,
Is there any way to create circular non-proportional zones on IgxGeographicMapComponent? So, that after zooming in/out on the map, the zone radius should not change.
I tried creating circular zones using IgxGeographicProportionalSymbolSeriesComponent. [Attaching code and screenshots]
Link: - Map | Data Visualization Tools | Scatter Proportional Series | Data Binding | Infragistics
But, after zooming in/out on the map, the circle is changing proportionally. As you can see in image 1 and 2.
Kindly, suggest any alternative approach.
CODE:
HTML:
<igx-geographic-map #map width="100%" height="100%" zoomable="true" > </igx-geographic-map>
DATA:
Image 1: Default loaded image.
Image 2: Little zoomed in image.
Just a follow up! Can anyone help me on this?
Hello and thank you for contacting Infragistics. I would try using our Bubble Series for the geographic map.
eg.
https://www.infragistics.com/products/ignite-ui-angular/angular/components/geo-map-type-scatter-bubble-series
To create non-proportional circular zones on IgxGeographicMapComponent, switch to IgxGeographicShapeSeriesComponent. Calculate the circle's radius in meters based on zoom and define its points. Adapt the code to your requirements.
