Hello sir/mam,
Actually, I wanted to ask that if i use method like hide column show column. Will it create any transaction or call any Event like reweditstart, rowending or any. And if I use end edit and start edit does it creats any transaction or call any record? I
Hi Rohit, when you use methods like hideColumn or showColumn, it typically does not trigger events like rowEditStart or rowEnding. However, using startEdit and endEdit can create transactions and may trigger events depending on the specific implementation of the grid or table you are using. Always check the sports games documentation for the specific library you're working with for more details.
Inat Box Android version is one of the best apps for streaming live TV, movies, sports, and trending entertainment from around the world. The app is lightweight, fast, and designed to run smoothly on all Android devices, including low-spec phones, without crashing or lagging.https://inatboxdl.com.tr/
I like how HDO Box APK website offers a huge library of movies and TV shows. It’s updated regularly, so I can always find the latest releases. The subtitles feature works perfectly in multiple languages.
When you use UI-level methods such as hideColumn or showColumn, they generally do not trigger data-layer events like rowEditStart, rowEnding, or any record-level transactions, because these actions only modify the visual state of the grid and not the underlying dataset. In contrast, calling startEdit or endEdit can initiate edit-related events since they interact directly with the row’s data lifecycle—however, they still won’t create a database transaction unless your system explicitly binds those events to commit operations. Think of it like attending an NYS 18 hour course in Batavia, NY: adjusting the classroom setup (similar to hiding/showing columns) doesn’t affect your certification process, but starting or completing the required modules (similar to startEdit/endEdit) does engage the official workflow.
Vedu Movie App lets you watch movies, TV shows, and web series anytime, anywhere. It’s easy to use, fast, and perfect for enjoying your favorite entertainment on the go. clic here
