400
Fixing Columns in igGrid should show only single 'Add New Row' button for entire row
I am very new in "infragistics" "igGrid" control.
The issue I am facing here is, when updating is enabled in combination with Column Fixing, there are two separate 'Add new row' buttons showing, one for the Fixed Columns area and one for the Non-Fixed Columns area.
I want that only single 'Add new row' buttons should come not separate buttons for every Fixed column area in a particular row.
Also, please let me know Is this a default setting of igGrid to show each time 'Add New Row' button for each Fixed Column area ?
Is there any property I can set in HTML code rather then writing some JavaScript function, to solve the issue I am facing ?
Please suggest some solution. Thanks in advance.
