400
"margin-left" css property is not working in "iggriddatarendered" event.
I am trying to set "margin-left" in igGrid cells, inside "iggriddatarendered" event, like below:
grid.on("iggriddatarendered", function(evt,ui){
var gridId = evt.target.id; //getting gridId of current controller
var columnIndex;
if(gridId == "_IndexPro")
for(i = 0; i <= 1="" i="" br=""> {
columnIndex = $("#" + gridId + "_" + "_DESC_Column").data("columnIndex")-1;
$(grid.igGrid("cellAt", columnIndex, i)).css('margin-left, '20px');
All other css properties are working fine here except "margin-left"
Please let me know what is missing in my code? How to set margin-left in my above code ?
Thanks in advance
  • 235
    Suggested Answer
    Hello Pree Khanna,
    Since the igGrid acts in ways similar to a plain html table, the styling of the cells is very similar as well. The css margin properties, just like for the html table if are set for a cell will not be taken into account, because that would have more negative effects and that's why it is standard for all browsers.
    I assume you are looking to shift the content of the cells to the right and there could be two ways of doing that:
    One way that can be achieved by setting the padding-left instead of the margin-left.
    Another way would be to wrap the content of each cell with a div element, and then set the margin-left attribute for those div elements.
    The wrapping of the content can be achieved by setting the template option for each column. It would look something like the code bellow:
    { headerText: "Product Name", key: "Name", dataType: "string", template: "<div class='myContentClass' >${Name}</div>" }
    Let me know if you need more information.
    Svetoslav Krastev,
