Hi Team
1. I want max value validation popup to hide on focus out for igNumericEditor editor.
2. I want this validation to be done on key up, now it is happening in focus out.
3. Is it possible to show the alert as label message bottom of the control.
Hello Sankaran,
To hide max value validation you can you can use “ validatorOptions ” and make it required false.
http://www.igniteui.com/help/api/2015.2/ui.ignumericeditor#options:validatorOptions
For your 2nd requirement I would like to know if you want to have validation on every character when you are writing something?
For your 3rd requirement I am working on it and I will provide you an update by EOD tomorrow.
If you have any further questions or concerns with this issue, please let me know.
I discussed the 3rd point with the team and would like to know by showing the validation message on the label what are you looking to achieve and what is the desired output?
To set the validation on label you can use valueChanged event. valueChanged event is raised after value in editor was changed. It can be raised on lost focus or on spin events.
In this event you can assign maxValExceedSetErrMsg string to label.
Your code would look like as :
valueChanged: function (evt, ui) {
$('#lblMessage').text($.ig.util.stringFormat($.ig.Editor.locale.maxValExceedSetErrMsg,999999));
I have created a sample application to demonstrate the same behavior. Find the attachment and let me know if you need further assistance.
