555
Filtering issue - Unable to get property 'push' of undefined or null reference
I am using igHierarchical grid using Load on Demand and row level editing.
I am using Simple Filtering feature which works fine the first time the grid is loaded. However if I make a change to the row and click on done I am not able to use this feature and it throws the following error:
Unhandled exception at line 23, column 15086 in localhost:31607/.../infragistics.ui.editors.js
0x800a138f - JavaScript runtime error: Unable to get property 'push' of undefined or null reference
On clicking on done , when saveChanges is called I need to call
grid.igHierarchicalGrid("dataBind"); and expand the grid using
var parentGrid = $("#igGrid").igHierarchicalGrid("rootWidget");
var domElement = parentGrid.rowById(rowID);
if (domElement != null) {
 $("#igGrid").igHierarchicalGrid("expand", domElement, function () {
After this is called the grid is refreshed with the latest values from the DB and the grid is expanded, but when I click on the filter icon on any of the columns and click on any option e.g Starts with it throws the above Js error.
I do not need to refresh the grid from the DB but want to have filter functionality work as it is.
Can you please help me with this?
Regards
Singh
