The igGrid column editor EditorType(ColumnEditorType.Date) with DataMode(DateEditorDataMode.Date) appears to load the cell editor with null when the column is clicked in .NET Core 2.0
(see attached screen snap)
This same code works correctly in ASP.NET 4.6.1 (the cell editor is loaded with “05:00”)
I’ve had such trouble with this forum editor, so have attached a link to the example zipped solution on one-drive instead:https://1drv.ms/u/s!Asqef4XMXF_I8QGw81kUwEPTTKpN
Environment:Visual Studio 15.5.5IgniteUI (17.2.456)Infragistics.Web.AspNetCore (6.17.2.211)
Screenshot.zip
Hello Terry,
I am currently looking at this matter for you. I will get back to you until the end if the business day tomorrow, 2/22/2018, to update you with my findings.
Please feel free to continue sending updates to this case at any time.
Regards,Vasya KacheshmarovaAssociate Software DeveloperInfragistics
Thank you for your patience while I was looking into this matter for you.
I tried reproducing the described behavior in an isolated sample. I removed all the code that is not directly related to the grid configuration and I was not able to replicate the empty editor when edit mode is entered.
When I enter edit mode the value for the cell editor is correctly set to the cell value. I tested this under Chrome, Firefox and Edge latest versions with Infragistics.AspNetCore package version 6.17.2.211.
Here you will find my sample. Please test it on your side and let me know what is the result. If the issue is still reproducible can you please provide me steps to reproduce and any details that you consider relevant.
Vasya:
(forgot to include this above...)
Maya had sent the service release/patch to verify if it fixed this problem - it did...
https://www.infragistics.com/community/forums/f/ignite-ui-for-javascript/111794/iggrid-paging-is-not-working-correctly-with-vs2017-net-core-2-0
(The grid dies a horrible death with Infragistics.Web.AspNetCore (6.17.2.202))
Thank you!
Terry Tiggemann
I downloaded your sample project, but it will not compile on this machine (the service release Maya sent does not install properly):
These are the errors I get:
NuGet package restore failed.1>------ Build started: Project: igGridEditor, Configuration: Debug Any CPU ------1>C:\Temp\igGridEditor\igGridEditor.csproj : error NU1102: Unable to find package IgniteUI with version (>= 17.2.459)1>C:\Temp\igGridEditor\igGridEditor.csproj : error NU1102: - Found 10 version(s) in nuget.org [ Nearest version: 17.2.456 ]1>C:\Temp\igGridEditor\igGridEditor.csproj : error NU1102: - Found 1 version(s) in Infragistics (Local) [ Nearest version: 17.2.456 ]1>C:\Temp\igGridEditor\igGridEditor.csproj : error NU1102: - Found 0 version(s) in Microsoft Visual Studio Offline Packages1>igGridEditor -> C:\Temp\igGridEditor\bin\Debug\netcoreapp2.0\igGridEditor.dll1>Done building project "igGridEditor.csproj" -- FAILED.========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
How would I get an update? - the IG Platform Installer is stuck at:
IgniteUI (17.2.456)Infragistics.Web.AspNetCore (6.17.2.202))
