I've been trying to filter my data by a date column displayed in "yyyy-MM-dd HH:mm:ss" format, but when I type in the filter, It only filter by Date (“yyyy-MM-dd”) ignoring the Time.
Time is not in the controller URI and it also happens with custom local data arrays.
Can you bring me an example of implementation?
I also been trying using a custom filter that sets the filter AFTER and BEFORE but it has the same problem. If you have a solution it will be great.
I have already tried this but doesn’t work with newest versions
https://www.infragistics.com/community/forums/f/ignite-ui-for-javascript/86635/iggrid-and-igdatepicker-display-input-format-for-date-column
Here some of my versions:
Infragistics.Web.Loader 15.2.20152.2081
jQuery JavaScript Library v1.10.2
Infragistics.Web.ClientUI data source localization resources 15.2.20152.2081
Infragistics.Web.ClientUI Widget 16.2.20162.2040
Hello Jose,
Currently the grid doesn't support filtering by time. This is planned for future release, but I could not give an exact estimate when it will be officially release. Here is the backlog item for your reference: https://github.com/IgniteUI/ignite-ui/issues/1601
If I can provide with any other assistance, please let me know.
Regards,Tsanna
