i wanted to check or uncheck SelectAll header checkbox on specific condition. so how can i check do that programmatically.
I found some workaround to do it programmatically.
$('#ig1').find('[name="hchk"]').data("chk","off").find("span").removeClass( "ui-igcheckbox-normal-off" ).addClass( "ui-igcheckbox-normal-off" );
but above work around fail when checkbox clicked and checked previously and using above code i unchecked it and then clicked to checked that time it actually perform deselection of rows but it must perform Selection of all rows.
Hello Adhikar,
Please check the attached sample: I initialize a grid that has a checkbox in the first column header - it toggles the checkboxes for the whole column. There is a grid option "renderCheckboxes" which I have set to "true" - it renders checkboxes for every boolean column automatically. As some customization is required, here is what I do:
If you have any further questions regarding this matter, or you need any additional assistance, feel free to contact me.
SelectAllCheckboxSample.zip
jQuery is() method is to check the current matched set of elements against a selector, element, or jQuery object and return true if at least one of these elements matches the given arguments. If no element fits, or the selector is not valid, then the response will be 'false'. This method traverses along the DOM elements to find a match, which satisfies the passed parameter.
if ($("input[type=checkbox]").is(":checked")) { alert("Checked");}
