30
Infragistics().DataChart do not get rendered in bootstrap tab
I am using ignite ui v18.1 (latest version) MVC5 Razor ASP.NET
I have a requirement of implementing  multiple charts inside bootstrap tabs
However chart in first tab which is a active tab get rendered correctly but for other tab which is a non active tab gets the following issue
Uncaught TypeError: c.b is not a function
at Class.be (infragistics.dv.js:222)
at Class.cs (infragistics.dv.js:220)
at Class.cs (infragistics.dv.js:230)
at Class.provideContainer (infragistics.dv.js:220)
at Class._renderChartContainer (infragistics.dv.js:901)
at Class._create (infragistics.dv.js:899)
at $.(:54492/anonymous function).(anonymous function)._create (localhost:54492/.../infragistics.dv.js:1023:7165)
at $.(:54492/anonymous function).(anonymous function)._create (localhost:54492/.../jquery-ui.js:415:25)
at $.(:54492/anonymous function).(anonymous function)._createWidget (localhost:54492/.../jquery-ui.js:585:8)
at $.(:54492/anonymous function).(anonymous function).$.Widget._createWidget (localhost:54492/.../infragistics.core.js:346:19420)
Sample code
@(Html.Infragistics()
                    .DataChart(Model)
                    .ID("chart")
                    .DataSourceUrl(Url.Action("get-chart-data"))
                    .Height("300")
                    .Title("Auctioned MW - UP Direction")
                    .Axes(axes =>
                        axes.CategoryX("xaxis")
                        .Label(item => item.BlockDataDateTime);
                        axes.NumericY("yAxis");
                    .Series(series =>
                        series.Line("mwSeries")
                        .Title("MW Up")
                        .XAxis("xaxis")
                        .YAxis("yAxis")
                        .ValueMemberPath(item => item.AuctionedMwUp)
                        .MarkerType(MarkerType.Circle)
                        .Brush("rgba(255, 0, 0, 1)")
                        .MarkerBrush("rgba(255, 0, 0, 1)")
                        .ShowTooltip(true)
                        .Legend(lenged => lenged.ID("lenged"));
                    .DataBind()
                    .Render()
