Hey!
I have several grids on a page that implement the "Delete Row" - feature. It works fine until I scroll in the table, then the button moves a bit down. The further I scroll the further the button moves, until can't see it anymore (see attached images).
I assume that's because the button has absolute positioning, and the position is calculated (in part) by how far the user scrolled down.
That would be correct behavior if I would be scrolling on the page, but in this case the user scrolls inside the container.
With every step I scroll, the button moves about 100px further down.
Did I do something wrong, or can this be fixed somehow?
We're using Ignite UI 17.2.
Quick update for future reference:
We couldn't downgrade jQuery (too many side effects), but I found a workaround for our use case:
var fixDeleteButton = function (gridId) { var ubodySelector = "#" + gridId + ">tbody"; var fbodySelector = "#" + gridId + "_fixed>tbody"; $("#" + gridId + "_container").on({ "mouseenter.deletebutton": function (evt) { var row = $(evt.target).parent(); var rowGrp = row.siblings().add(row); var db = $("#" + gridId + "_updating_deletehover"); if (db.length) { var top = row.offset().top - rowGrp.first().offset().top + (row.outerHeight() - db.outerHeight()) / 2; db.css({ top: top }); } } }, ubodySelector + ">tr," + fbodySelector + ">tr"); };
This may not be a perfect solution, but we couldn't find any bugs thus far.
