1020
Regarding the ID of autogenerated div tags and textboxes in Ignite UI combo
When recording the screen using the “Katalon recording tool”, we are able to record but the while executing the script it became failed because absence of attribute Id (Id is not available for the IgniteUI control present in the screen.)
Many of the auto generated div tags & textboxes used in Ignite UI Combo doesn't have ID attribute set.
Kindly let us know whether it's possible to have the id for the controls.
Thanks in Advance.
  • 20120
    Hello JG Giridhar,
    Thank you for contacting us!
    Each of our widgets have an ID, as for the child html elements contained in it, no they do not have. These elements are changed dynamically based on the widget configuration, functionalities and actions that you take in order to use the widget.
