15
MaskInput number format show dash (-) instead of zero
using ultragrid want to format my column. I want to format my number value dash ('-') instead of zero so if number is zero then should show dash ('-') sign else number. what would be the format or MaskInput for specific ultragrid column? sample code would be appreciated pls.
e.g.:
MyNumberFormatted      MyNumberNoFormat
       -                     0
       5                     5
       -                     0
       1                     1
  • 17150
    Hello Haseeb,
    In order to ensure that your question is addressed correctly I will need some additional clarifications. Can you please answer the following questions:
    1. Are you using igGrid from the Ignite UI for JavaScript or WebDataGrid from the ASP.NET controls?
    2. What is the column type of this column, is it "string" or "number"?
    Answering these questions is going to be highly appreciated and will help me decide how should we proceed further.
