I set dropdown template for a column cell and all is good until I go to next page or scroll down then templates disappear from the column.
How to fix that? thanks
$("#grid1").igGrid({ width: '100%', columns: DefaultColumns, dataSource: northwindCustomers, rendered: function (evt, ui) { tmpl = "<div id=grdlist_${CustomerID}></div>"; $('#grid1').igGrid('setColumnTemplate', 'CompanyName', tmpl); },
features: [ { name: 'Paging', recordCountKey: 'TotalRecordsCount', pageIndexUrlKey: 'page', pageSizeUrlKey: 'pageSize', pageSize: 5, type: 'remote', pageIndexChanging: function (evt, ui) { var ds = $("#grid1").data('igGrid').dataSource; ds.settings.urlParamsEncoded = function (item, params) { params.extraParams = { input: "text here" }; }; } }],
Hello Andrew,
I am currently trying to reproduce the described behavior in a working sample. I will keep you posted on my progress and I will get back to you soon with more information or questions.
Please feel free to continue sending updates to this case ta any time.
I created a small sample, using the snippets provided, trying to replicate the behavior on your side.
I am adding a div element as a template for the “Name” column and I am assigning the div`s id to the current row id. After switching to different pages, scrolling up and down and I inspect the cell I am able to see the div element with the correct id.
Attached you will find my sample. Please test it on your side and let me know how it behaves on your side. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it so that it replicates the issue, and send it back to me along with steps to reproduce. Having a small application on my side, which I can debug, is going to be highly appreciated and helpful in finding the root cause of the behavior.
2845.igGridCellTemplate1.zip
Thank you Vasya!
Your example works fine but with static template only like e.g. button:
tmpl = "<div id=grdlist_${ProductID}><button type='button'>X_${ProductID}</button></div>"; $('#grid1').igGrid('setColumnTemplate', 'Name', tmpl);
but I have template with custom combobox which is filled with few rows and that's not working,
only first page is OK, getting combo with dropdown but when I go to next page combo is gone, when come back again to page 1 it's also gone.
I tried to reload template in pageIndexChanging: function (evt, ui) {} but no luck so far.
Initially I load template with data like this:
dataBound: function (evt, ui) { dataSource = $("#grid1").igGrid("option", "dataSource"); $.each(dataSource, function (index, row) { $("#grdlist_" + row.ProductID).CustomList({ 'id': 'grdlist_' + row.ProductID, 'dataSource': ListData, 'valueKey': 'col1', 'textKey': 'col2', 'selected': row.ProductID, 'externalColumns': ListCols, 'callback': onGridListSelection }); });
var ListCols = [ { headerText: "ID", key: "col1", dataType: "string", width: "50%" }, { headerText: "Product", key: "col2", dataType: "string", width: "50%" }];
My suggestion is to initialize the custom combobox widget inside the pagerRendered event handler of the Paging feature:
pagerRendered: function (evt, ui) { var dataSource = ui.dataSource.recordsForPage(ui.owner.pageIndex()); $.each(dataSource, function (index, row) { $("#grdlist_" + row.ProductID).CustomList({ 'id': 'grdlist_' + row.ProductID, 'dataSource': ListData, 'valueKey': 'col1', 'textKey': 'col2', 'selected': row.ProductID, 'externalColumns': ListCols, 'callback': onGridListSelection }); }); }
I have modified and attached Vasya' s sample for your reference.
2703.igGridCellTemplate1.zip
thanks Martin,
that is working nice as I needed.
What is the trick now to maintain selection between the pages?
this, doesn't seem to have any effect:
{ name: "Selection", persist: true },
