MVC3 / C# applicationThe following (excerpt) code is working just fine, displays the correct phone# @model DataRepository.StudentDataCollection @using Infragistics.Web.Mvc <div id="pinfoL4C1" class="s4c1"> @Html.LabelFor(s => s.HomePhone): @Html.TextBoxFor(s => s.HomePhone) @Html.ValidationMessageFor(s => s.HomePhone, "*") </div>I'd like to use the MaskEditor, so I changed my code to the following (based on the sample code) <div id="pinfoL4C1" class="s4c1"> @Html.LabelFor(s => s.HomePhone): @(Html.Infragistics().MaskEditor() .ID("HomePhone") .Width(160) .InputMask("(000) 000-0000") .Required(false) .ValidatorOptions(m => m.OnSubmit(false).OnChange(true).OnBlur(true).ShowIcon(true)) .Render()) </div>With the above, I have no value displaying. Firebug shows the following: <div id="pinfoL4C1" class="s4c1"> <label for="HomePhone">HomePhone</label> : <input id="HomePhone" class="ui-igedit-field ui-igedit ui-state-default ui-widget ui-corner-all" style="display: inline-block; width: 154px;" maxlength="19"> <input type="hidden" name="HomePhone" value="() -"> <script type="text/javascript"> //<!--<![CDATA[ $(function () {$('#HomePhone').igEditor({ type: 1, dataMode: 'alltext', width: 160, inputMask: '(000) 000-0000', required: false, validatorOptions: { onsubmit: false, onchange: true, onblur: true, showIcon: true }, inputName: 'HomePhone' });}); //]]>--> </script> </div>
I've cleared cache, replaced the @Html.LabelFor() with literal text (just in case it was causing any confusion), and I'm not seeing my phone #.
The data value is in the format "(918) 555-1234".
I'm doing the igloader in javascript
$(document).ready(function () { $.ig.loader({ scriptPath: '../../Scripts/libs/ig/js/', cssPath: '../../Content/ig/css/', resources: 'igUpload,igCombo,igValidator,igShared', }); ...
Can anybody help?
Bruce
Never mind... I guess I was expecting the automatic model binding.
- Bruce
