Can you put a title on an Ignite UI gauge to indicate what the gauge is measuring? It seems like I should be able to, but I can't seem to find any properties for it.
This would currently be done by simply placing a title above the gauge component. In which case you may also wish to hide the default border that appears above the gauge. If you'd prefer to have a built in title, feel free to make a feature request to this effect. Keep in mind you will probably have greater control over the title's appearance as a separate DOM element, though. If you'd prefer it incorporated, it would help if you could detail what type of configuration you would find useful for the title.
-Graham
