Hello Infragistics,
I am trying to plot different data sets which is necessitating the use of series level datasources: I seem to have ran across a bug in the behavior of the chart as it is not displaying the bars when I set the datasource at series level; it does work if I set the datasource at the chart level but that does not meet my needs. Interestingly by modifying the values to be charted I can see it is setting the chart limits but not drawing the bars.Finally and most maddeningly I actually can get the stacked series to show up if I give the parent series a specific name, in the fiddle for example the name "stackedColumn" seems to work while "Robert" fails; in my actual project the name "stackedColumn" does not seem to work but another string that is passed in as an argument (but I don't seem to be able to use just any string, and it doesn't work in the fiddle )
http://jsfiddle.net/mu4sza4e/6/
Signed,
Andrew Bednarski
Hello Andrew,
When you set the datasource on the series you also have to set it on the x-axis so it knows how to interpret the data.
http://www.igniteui.com/help/api/2016.1/ui.igDataChart#options:series.dataSource
