Hi
I am new at Infragistics and I get some error messages that I could not solve. I'm using ASP.NET MVC (.NET framework 4.6.1) with JQuery 3.0.0. I followed the getting started guide (https://www.igniteui.com/help/iggrid-developing-asp-net-mvc-applications-with-iggrid#getting-started) and I get this errors:
I am new to Infragistics and I get a number of error messages that I cannot resolve. I use ASP.NET MVC (.NET framework 4.6.1) with JQuery 3.0.0. I have followed the getting started guide (www.igniteui.com/.../iggrid-developing-asp-net-mvc-applications-with-iggrid and get the following error messages:
The grid is not showing because of this.
I started with JQuery version 3.3.1, but I found a message about how there are problems with this version. That is why I am now using version 3.0.0.
In the BundleConfig file I have created these bundles:
Which I use in my view as @Scripts.Render("~/bundles/IgniteUI") and @Scripts.Render("~/bundles/IgniteUI/css").
I also added the proper usings to my view: @using FremachWebApps.Areas.Diepenbeek.Models @using Infragistics.Web.Mvc
Then I wanted to add the grid to my view as followed: @(Html.Infragistics().Grid(Model.labotTimeGridModel)).My model is a viewmodel with a GridModel and some other Lists.
According to the getting started guide, this would be enough, but I still get these errors. In the devtools I can see that my datasource is found and the records are included.
Is there something else I should do to fix this JQuery issue? Also why am I getting an unexpected token error on the css files of Infragistics?
Thanks you.
Hello Ronny,
I am glad that you managed to resolve your issue.
Thank you for Infragistics components.
Hello Martin
I have got it working by adding this to the head:
<!-- Ignite UI Required Combined CSS Files --> <link href="">cdn-na.infragistics.com/.../infragistics.theme.css" rel="stylesheet" /> <link href="">cdn-na.infragistics.com/.../infragistics.css" rel="stylesheet" /> @Scripts.Render("~/bundles/modernizr") <script src="">code.jquery.com/.../script> <script src="">code.jquery.com/.../script> <!-- Ignite UI Required Combined JavaScript Files --> <script src="">cdn-na.infragistics.com/.../script> <script src="">cdn-na.infragistics.com/.../script> <script src="">cdn-na.infragistics.com/.../script>
I think that the latest version of Infragistics was not compatible with the version I had for Jquery?
Now it works fine.
Hello Rony,
Thank you for contacting Infragistics.
It would be highly appreciated if you could send a sample where the issue is reproduced so we can observe it on our side.
I have attached a folder where you can upload the MVC solution. Please archive it before uploading.
Let me know after the uploading has finished.
You can find the folder here.
