Hi
I have tried to add a multiline text editor without any luck:
@Html.Infragistics().TextEditor().ID("dialogEmailDetail").TextMode(TextEditorTextMode.Multiline).Height(100).Width(205).Render()
I am using MVC4. Nothing happens when you hit the enter key and try to go multiline.
Please help.
Hello the_corps,
Thank you for posting in our forums!
The default behavior in the igEditors is to use Shift + Enter to create a new line. By setting the hideEnterKey option of the editor to false, you can enable new lines through pressing Enter without Shift.
In recent releases of IgniteUI, a bug has been discovered with this option where after creating a new line, any new input will wipe out the contents of the editor. I have discussed this with our developers and am submitting a development issue to address this. I will have more information on this for you tomorrow.
I have created a support case for you with an ID of CAS-132426-B6B5P0. The matter has been determined to be a development issue and has been logged in our tracking system with ID: 166071.
I will leave this case open and update you with any new information. You can view the status of the development issue connected to this case by going to the “Account” tab on our website, selecting "My Support Activity" and then this support case will be listed there. Then, you may select the "Development Issues" tab to view details of this development issue.
