15
Grid Template Columns
The react sample for IgrTemplateColumn shows manually generated HTML for the cell contents.  This is not very react-ish.  Is there a way to specify a react component for the IgrTemplateColumn?
  • 28925
    Hello Fred,
    Thank you for contacting Infragistics. As the online documentation suggests using onAddressCellUpdating to populate the fields is the approach to take. Do you wish to simply have a render method and attach it to a property on the field?
    You can suggest new product ideas for future versions (or vote for existing ones) at <https://www.infragistics.com/community/ideas>.
    Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
