130
Facing issue while styling IgrDataGrid and context menu option
Hi
I have created a IgrDataGrid and now I'm facing some issues with it's styling and one of its feature. Currently my grid looks like this below image and in this I have 5 major issues which I'm facing. If someone can help me with the approach for this issue.
Issue 1:-  For the functionality of column chooser I have used "IgrDataGridToolbar". In this toolbar as you can see in the above image I want to align the column chooser button within the toolbar but it's border is overflowing from the table which is not looking good. For the same I tried to apply the CSS but it's not working. So what can be the approach for this?
Issue 2:- When I open column chooser option it's size is very big(as shown in image below). I want to minimize the size of column chooser when it's selected or clicked.
Issue 3:- In column chooser if I select any column(for example "symbol") then the column with name symbol disappears which is correct but the IgrDataGridToolbar width remains same(as shown in image below) which looks ugly. Is there any way to manipulate the width of the IgrDataGridToolbar when the width if IgrDataGrid is changed.
Issue 4:- When I click on the options icon in the header the background of the options is white by default(as shown in image below). Is there any way to change the background color of the options when it's clicked. And also can I customize the column options by my own(Can I give my own options in the options menu).
Issue 5:- I want to add a context menu for my grid. When I right click on the grid it opens a customized menu. Is it possible to do so?
For the reference I am attaching my exact code as well. Please have a look and it and suggest the solutions for the above mentioned issues.
import React from 'react';
import { IgrDataBindingEventArgs, IgrDataGrid, IgrDataGridCellEventArgs, IgrDataGridModule, IgrDataGridToolbar, IgrDataGridToolbarModule, IgrGridColumnOptionsModule, IgrTemplateHeader, TemplateHeaderCellUpdatingEventArgs } from 'igniteui-react-grids';
import { IgrTextColumn } from 'igniteui-react-grids';
import "../css/InfragisticsGrid.css";
import { IgrTemplateCellInfo } from "igniteui-react-grids";
import { IgrSparklineModule } from 'igniteui-react-charts';
IgrDataGridModule.register();
IgrGridColumnOptionsModule.register();
IgrDataGridToolbarModule.register();
IgrSparklineModule.register();
let rowExpanded = false;
export default class DataGridBindingLocalData extends React.Component<any, any> {
    public data!: any[];
    public grid!: IgrDataGrid;
    public toolbar!: IgrDataGridToolbar;
    onCellClick = () => {
        rowExpanded = true;
        console.log("Clicked");
    constructor(props: any) {
        super(props);
        this.state = { componentVisible: true }
        this.initData();
    public onGridRef = (grid: IgrDataGrid) => {
        if (!grid) { return; }
        else{
        this.grid = grid;
        if (this.toolbar !== null) {
            this.toolbar.targetGrid = this.grid;
    public onToolbarRef = (toolbar: IgrDataGridToolbar) => {
        this.toolbar = toolbar;
    public render(): JSX.Element {
        return (
                <IgrDataGridToolbar
                    ref={this.onToolbarRef}
                    toolbarTitle="Watchlist"
                    columnChooser="true"
                    backgroundColor='var(--input-background)'
                    dialogBackgroundColor='var(--input-background)'
                    toolbarTitleColor='var(--text-2)'
                    height="25px"
                    width='27.5%'
                <IgrDataGrid
                    ref={this.onGridRef}
                    width="27.7%"
                    height="calc(100% - 2.75rem)"
                    dataSource={this.data}
                    autoGenerateColumns="false"
                    cornerRadiusBottomLeft={10}
                    cornerRadiusBottomRight={10}
                    columnMovingMode="Deferred"
                    selectionMode="SingleRow"
                    cellBackground="var(--input-background)"
                    cellTextColor="var(--text-2)"
                    border="#67605999"
                    cellSelectedBackground="var(--dark-hover)"
                    headerTextColor="var(--text-2)"
                    headerBackground="var(--input-background)"
                    rowHoverBackground="var(--input-background)"
                    rowSeparatorBackground="var(--backgroung-dark)"
                    headerRowSeparatorBackground="var(--backgroung-dark)"
                    headerSeparatorBackground="var(--input-background)"
                    summaryRootValueTextColor="var(--text-2)"
                    rowHeight={25}
                    headerHeight={25}
                    headerSortIndicatorColor="var(--text-2)"
                    isRowHoverEnabled={true}
                    columnOptionsIconColor="var(--text-2)"
                    columnOptionsIconAlignment={3}
                    isColumnOptionsEnabled="true"
                    isToolbarColumnChooserVisible={true}
                    isGroupExpandedDefault={true}
                    cellClicked={this.onCellClick}
                    isGroupCollapsable="true"
                    columnShowingAnimationMode="slideFromRightAndFadeIn"
                    columnHidingAnimationMode="slideToRightAndFadeOut"
                    columnMovingAnimationMode="SlideOver"
                    <IgrTextColumn field="Symbol" headerText="Symbol" width="113" dataBound={this.onCellDataBound} verticalAlignment="center"/>
                    <IgrTextColumn field="Bid" headerText="Bid" width="83" dataBound={this.onCellDataBound} textColor="var(--dark-bid)" rowHoverBackground='var(--dark-bid-hover)' verticalAlignment="center"/>
                    <IgrTextColumn field="Ask" headerText="Ask" width="86" dataBound={this.onCellDataBound} textColor="var(--dark-ask)" rowHoverBackground='var(--dark-ask-hover)' verticalAlignment="center"/>
                    <IgrTextColumn field="Price" headerText="Price" width="94" dataBound={this.onCellDataBound} verticalAlignment="center" />
                </IgrDataGrid>
    public getRandomNumber(min: number, max: number): number {
        return Math.round(min + Math.random() * (max - min));
    public getRandomItem(array: any[]): any {
        const index = Math.round(this.getRandomNumber(0, array.length - 1));
        return array[index];
    public initData() {
        const symbols: string[] = ["AMZN", "APPL", "FB", "TSLA", "GOOG",];
        const bid: number[] = [92.34, 94.56, 108.12, 80.47, 75.89]
        const ask: number[] = [92.34, 94.56, 108.12, 80.47, 75.89]
        const prices: number[] = [11.11, 19.01, 11.05, 12.12, 13.11]
        const wishlistData: any[] = [];
        for (let i = 0; i < 10; i++) {
            wishlistData.push({
                Symbol: this.getRandomItem(symbols),
                Bid: this.getRandomItem(bid),
                Ask: this.getRandomItem(ask),
                Price: this.getRandomItem(prices),
        this.data = wishlistData;
    public onCellDataBound = (s: any, e: IgrDataBindingEventArgs) => {
        let isAlternate = e.cellInfo.dataRow % 2 == 0;
        if (isAlternate) {
             e.cellInfo.background = "var(--dark-hover)";
Hoping for a positive response.
Thanks!!!
  • 33910
    Hello Avanish,
    I have been investigating into the behaviors you have asked about in this case, and I have some information for you. I will answer your questions in the order they were asked.
    1. There is some built-in padding to the column chooser button in the IgrDataGridToolbar. Much of the styling is hard-coded at this time though, and so you will need to get the element and style it programmatically. For this part, you can do this like so:
    let btn = document.getElementById("hideBtn");
    let actualBtn : HTMLButtonElement = btn.children[0] as HTMLButtonElement;
    actualBtn.style.padding = "0px";
    2. The height and width of the column chooser like above, appears to be hard-coded. You can change it programmatically like so:
    let elements = document.getElementsByClassName("igr-column-chooser");
    let chooser = elements[0];
    let chooserParent = chooser.parentElement;
    chooserParent.style.height = "200px";
    chooserParent.style.width = "200px";
    3. Unfortunately at this time, there is no implementation to keep the IgrDataGridToolbar the same width as the columns of the grid as they are separate elements. You will need to modify the width of the IgrDataGridToolbar programmatically in this case in order to keep it consistent. There are events for the different states of a column that may help you to track this such as the columnHiddenChanged event on the grid.
    4. Unfortunately with the current implementation, there does not exist a way to style the column options dialog or add elements to it. I would suggest creating a new product idea for this at our GitHub page for the Ignite UI for React toolset, here: https://github.com/IgniteUI/igniteui-react/issues.
    5. The Ignite UI for React toolset does not currently expose a context menu element, but you can catch when you right-click a cell in the IgrDataGrid by utilizing its cellClicked event and then use your own custom element as a context menu. If you would like to see a context menu potentially implemented in the Ignite UI for React toolset, I would recommend suggesting a new product idea for this by using the following link: https://github.com/IgniteUI/igniteui-react/issues.
