Hi guys,
Anyone knows how to add a KPI into my created chart (without having to add another data to the excel worksheet?)
Any help is well appreciated. :)
Cheers,
Wilfred
Hello Wilfred,
Thank you for posting at IG Forums!
It looks like you're trying to add a calculated column? Is this correct?
You can add new calculated fields but the values it uses must be fixed or result of a formula.
Let me know if I'm heading in the right direction.
I'm writing to you in order to check if you have further questions.
I will keep this case open for another three days while I wait for your response. If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Best regards.
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
Hi Javier,
I am revisiting this thread...
Don't know if you could see my uploaded image.
another link: http://tinypic.com/r/t8966w/9
Have a look pls.
Tks,
Hi Wilfred,
Could you tell us how do you have this KPI value?
Is it a certain field?
From what I see and trying to reach what you expected, I would suggest:
(Assuming that you have your KPI data in a separate field or a new calculated field as Javier suggested before)
I hope this might help for your case.
KPI Line
Hi there, I tried the method.
But I got a DOT (orange in colour) instead of a line...
Any help?
Do apologise if my response is so late. will follow up tightly next time.
Tks much!
