5
What are the reasons behind QBCFMonitorService not running error?
QuickBooks is the best and the most common accounting software used worldwide, but it requires numerous background services and processes to function in an efficient manner. One of the critical QuickBooks services is QBCFMonitorService. You may end up with QBCFMonitorService not running error while trying to run QuickBooks Database Server Manager to set up multi-user mode. However, several reasons evoke this error:
  • QuickBooks installed on the server is not properly set up to host company files in a multi-user environment.
  • Accidentally the QuickBooks Database Manager Service file (qbcfmonitorservice.exe) is deleted from the server.
  • You are using an outdated version of QuickBooks Database Server Manager.
To eliminate the QBCFMonitorService not running error, you must try to implement the resolution steps listed in this post.
