Hi, would anyone know is there a way to adjust the column widths on a grid style dashboard?
I have large $ figures and they are just all too close to each other and would like some distance.
Hi Brett,
You could adjust a column's width by tapping & holding over the column's header, a blue border line should appear, then, you should be able to adjust the width by "dragging" the edge of the borders away.
Please do not hesitate to contact me if you need any additional assistance.
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
This was a question that I had as well. I followed your suggestions and it worked perfectly.
Thanks!
Cindy
This no longer appears to work. Is there any way to adjust column width in the newer version?
