I haven't had any problems connecting to my sharepoint server, but this morning I'm getting a strange error with the Report Plus app on my IPAD:
Authentication Fails
The operation couldn't be completed. (DDXMLErrorDomain error1.)
Is anyone else getting this error? Connections to sharepoint work fine from other apps on the same ipad and other ipads we've tested with are having the same problem with ONLY this report plus app.
Brian,
Thank you for posting at IG Forums!
That looks like your server is not returning an XML response to SharePlus' request.
What authentication mode does your site use? Is your site published via Forefront or any other technology?
Looking forward to hearing from you,
It does uses forefront identity manager. Are there any specific requirements on our server required so that ReportPlus can connect? SharePlus works perfectly fine against our server.
Hello Brian,
It is really strange that SharePlus works but ReportPlus doesn't...
We would like to test it here in order to find what is causing this behavior and fix it.
Would you mind provide us with test credentials and the URL you're using in order to help you?
I've sent you an email for you to provide this information if possible.
I'll be looking forward to hearing from you,
HI I GET THE SAME ERROR IS THERE A FIX?
TOBY TARCZY
M: +447799133349
Have you tried changing your "User-Agent" to "ReportPlus" under Advanced settings?
