Dear Sirs,
is it possible in ReportPlus to change widths of bars in bar charts?
Is it possible on charts to format text lines? I.e. I have different names for different bars, but they are too long and instead of smth like "Assets for sale" i see only "Asse...". Is it possible to wrap them on two or more lines or smth else?
Is it possible to drill down from a chart? I see it is possible when using table view however very often it is necessary to be able to drill down on charts to check something on the fly.
I use Pro version of ReportPlus bought in Appstore.
THNX,
Ilya
Hello IIya,
Thank you for contacting Infragistics. 1. You can adjust a column's width by tapping & holding over the column's header. This will result in a blue border to appear and by dragging the edge of the border will result in increasing the width. 2. You can modify the chart style, in the visualization tab. There is a demonstration presented on our website. https://www.infragistics.com/enterprise-solutions/enterprise-mobility/reportplus 3. Bar charts should support drill down. An example can be found on the following forum post. https://www.infragistics.com/community/forums/f/reportplus/83673/how-to-display-a-local-file-is-the-drill-down-function-just-for-time-sierials 4. I believe multiline column header support is considered a new feature request. We really appreciate your feedback and we'd like you to add your idea here [https://www.infragistics.com/community/ideas] so you, and other users, can vote, comment and follow your idea: the higher the number of votes the higher are the chances of your idea being implemented in a future version of SharePlus.
Is there anything else I can help you with?
Hi!
Thank you for fast answer, however you answered only a part of my questions. Here are explanations, hope for your further help.
1. You misunderstood me. First question was not about a column width in grid or table view which you have already answered and I know it. My question was exactly about BAR CHART, I mean how to change width of the rectangles which are used in the bar charts for visualization.
2. Re multiline column header. I meant again Bar charts, not grids. I saw in the HR Dashboard that you positioned headers for bars not horizontally but with an angle. How to do it as it would solve my issue. E.g. I now see "Asset..." instead of "Assets for sale" on the bar chart (below the proper bar in the picture which visualize, not in the grid view). If to put this with an angle (not horizontally) it would help.
3. Bar charts drill down. I hve similar situation to shown in your example (column with Assets which can be broken to sub-assets and another column - values). However in my bar chart I can not get drill down. My source is MS SQL, not excel file.
Hello Ilya,
You cannot change width of the bars and the orientation of the x axis labels on the charts. When you "drill-down" the data, the x axis labels are on an angle to indicate that you are not on the top level and that its showing several aggregated columns.
Drill down support becomes available if the data has been aggregated in the pivot table with a Date field on the Rows placeholder, this will enable to move from the years view, to the months, and days view, by tapping on a chart column, or grid row.
OR if the data source is Analysis Services, which supports drill down at the data source.
