Trying to run the "AND" function in ReportPlus but keep getting a logical error. What is the best way to do this?
Hello Chad,
In order to add an "AND" function to your dashboard you will need to do the following:
Tap over the "Edit" button over the dashboard.
Once you do so, tap over the "Settings" button and you should see the function button over the "Values" section on the bottom of the screen.
Tap over the "+f(x)" (function) button, then select the "AND" function.
You can check out how to use the AND function in the following link:
http://spreadsheets.about.com/od/excelfunctions/qt/20080117_and.htm
Please let us know if there's anything else that I can do for you.
Gonzalo T Technical Support Engineer I Enterprise Mobility Infragistics, Inc.
