I have two columns in an ultrawebgrid with column type dropdown. I am selecting values from the dropdown in the ultrawebgrid and its working fine.
Now my requirement has changed and I want to bind editor controls on the basis of the seleted value in the first column.
Is it possible to set different column type or cell type (text box, dropdown) for different cells of the same column on the basis of the values selected in the first column?
Waiting for your quick response
I don't believe you can have different column types in the same column, but you might be able to use a template column and hide controls on a row-by-row basis.
HTH
