3338
How can I get the contents of a row cell for the client?
I am using a template column that has an image control in it.
Part of what I am trying to do is get the imageurl = getimage.aspx?id=    and then the id field from another cell on this row
if the keyfield of the row is called imageid
what is the syntax to put in the imageurl custom binding code expression that will provide the contents of the imageid cell?
  • 7694
    Please try to use JavaScript code below.
    <ClientSideEvents CellClickHandler="GetCellValue" />
        function GetCellValue(gridId, cellId){
            if(igtbl_getCellById(cellId).Element.childNodes.length>1){
                igtbl_getCellById(cellId).Element.childNodes[1].src="http://forums.infragistics.com/Themes/leanandgreen/images/rankicons/rankTop150.gif";
        </script>
    I hope this sample helps.
