I am using the Infragistics Build Version: 7.3.20073.1043 WebTree control. In the NodeChecked event handler, I'm using the client side getNodeById function of the tree control in the javascript. My code is as follows:
function folio_NodeChecked(treeId, nodeId, bChecked){ var selectedNode = igtree_getNodeById(nodeId); var childNodes = selectedNode.getChildNodes(); var parentNode = selectedNode.getParent(); if(bChecked) { var treeObject = igtree_getTreeById(treeId); var nodeObject = treeObject.getNodeById('24653'); alert(nodeObject); nodeObject.setChecked(false); }}
The problem is that treeObject.getNodeById('24653') doesnt seem to return a valid node. It is null. Later I realized that 24653 is the DataKey and not the NodeId. When I fired the NodeChecked event against the Node with DataKey = 24653 to see what was the NodeId, it returned "ctl00ContentPlaceHolderMaintreeFolio_2_1_1_3". This doesnt seem useful in my scenario. My problem is that in a NodeChecked eventhandler, I have the DataKey for a different node and I want to check/un-check it using the node.SetChecked() function. How can I get the NodeId starting from the DataKey for a node.
Please help.
You can use the property Tag of node to set ID and get in client side. Please take a look at the code below:
C#UltraWebTree1.Nodes[1].Tag = "24653";
JS code: var tag = selectedNode.getTag();
Also you have to use recursion method to find searched node.Sample recursion method:http://news.infragistics.com/forums/p/18534/67437.aspx#67437Hope this helps.
