I have this weird thing going on where it will work perfectly on a normal page but when I place it inside a Content place holder for use in my masterpage only certain days will allow me to click on them. The cursor turns from a pointer to a hand on only about half of the days.
A little help would be much appreciated. All of my pages are containted within masterpages.
Bobby
HI,
Check to see if you have the WebDateChooser's MinDate property set. If you do then any dates prior to the min date will not allow you to click on them. Otherwise I was unable to reproduce.
If the MinDate property were set it would give me the same results in and out of the masterpage.
However, I did check and nothing is set for either min or max.
I am wondering if there is some CSS property that is messing with it. Have there been any bugs with that?
I just noticed it consistently allows me to pick dates from the fourth column over for every month. Very strange!
Can you attach a small application that duplicates this issue?
Yes, I will make a small page this afternoon thanks for looking into it. I did trace it to the style sheet but not sure what it is that is causing it to break. When I remove the reference to the style sheet in the masterpage the calendar works perfectly.
