I am having UltrawebGrid and I am populating this grid in client side using javascript. I have a textbox in one of the columns. I am having two problems with it
1) when i type in some text, if i make a mistake, i am not able select the contents of the text using mouse and remove it. I need to press backspace to remove the contents. Is there a work around to remove this behavior? this is happening only with UltraWebGrid
2) I am not able to put a space when i type in the textbox, if I tab out and then tab in, i am able to put a space.
Please help
Regards,Anil
