Version: Infragistics2.WebUI.UltraWebGrid.v8.1
I am using the grid in a web part (currently just in an asp.net page)
Currently, I am doing the following:
1. If the page is a post back (grid data modified) - I check the first colum data type, and if it is checkboxes, i remove the column. The reason i do this is the number of rows and the row data may have changed, this ensures a new (empty) group of checkboxes that match the row when they are re added.
2. Load and Bind data to grid.
3. Re add checkbox column - myGrid.Columns.Insert(0, myCheckBoxes)
4. On the page, I have a submit button with an event handler to check the values:
(tried many different ways)
string check = row.cells.FromKey(TheCheckBox).value.tostring();
bool check2 = (bool)row.cells.FromKey(TheCheckBox).value;
bool check3 = (bool).row.Cells[0].Value;
Now, these boxes are ALWAYS false, no matter if i check them in the grid or not. With one exeption...in the PreRender method, I check some checkboxes in code:
myGrid.Rows[0].value = true;
myGrid.Rows[1].value = true;
When this page loads, as expected, the first two checkmarks are checked on the grid, and on submit are TRUE by using above methods. The wired thing is, if I uncheck them, they are still true when they are submitted! It seems that any user interaction is not picked up.
