I searched the forum for this and found and "old" thread about the issue but I didn't have luck with those tips provided in the thread.
I have a scenario where I have "hard-coded" root level node (Select all). Then I bind my ObservableCollection to that item's ItemsSource. Here's the XAML of my scenario.
<ig:XamTree CheckBoxVisibility="Visible" CheckBoxMode="Auto"><ig:XamTreeItem Header="Select/Deselect all" ItemsSource="{Binding MyObjects}"><ig:XamTreeItem.ItemTemplate><DataTemplate><ig:XamTreeItem IsChecked="{Binding IsSelected, Mode=TwoWay}" Header="{Binding Name}"/></DataTemplate></ig:XamTreeItem.ItemTemplate></ig:XamTreeItem></ig:XamTree>
This doesn't work. The CheckBox doesn't update the property as expected. I got this idea by combining few samples from these forums. The basic idea came from this example:
<ig:XamTree CheckBoxVisibility="Visible" CheckBoxMode="Auto"><ig:XamTreeItem Header="Select/Deselect all" ItemsSource="{Binding MyObjects}"><ig:XamTreeItem.ItemTemplate><DataTemplate><TextBlock Text="{Binding Name}" /></DataTemplate></ig:XamTreeItem.ItemTemplate></ig:XamTreeItem></ig:XamTree>
This looks better so basicly I need this but added with the possibility to bind the CheckBox to a boolean property of MyObject. I'm using 10.2.20102.2066 version of your control.
Any ideas how to achieve this?
I got it working after some struggling. I needed to define both DefaultItemsContainer- and ItemTemplate -templates like this:
<ig:XamTree CheckBoxVisibility="Visible" CheckBoxMode="Auto" ><ig:XamTreeItem Header="Select/Deselect all" ItemsSource="{Binding MyObjects}"><ig:XamTreeItem.DefaultItemsContainer><DataTemplate><ig:XamTreeItem IsChecked="{Binding IsSelected, Mode=TwoWay}" /></DataTemplate></ig:XamTreeItem.DefaultItemsContainer><ig:XamTreeItem.ItemTemplate><DataTemplate><TextBlock Text="{Binding Name}" /></DataTemplate></ig:XamTreeItem.ItemTemplate></ig:XamTreeItem></ig:XamTree>
This seem to work fine. Hope this solution helps someone else too.
Awesome. Thanks for posting the solutions here. It did help me save time.
