I have the following scenario.
There is a XamWebChart with ZoomRectangle property enabled.
Our requirement is to get the DataPoints selected in the ZoomRectangle area(before or after zooming) so that we can process the data.
Any suggestions on how we can get the list of DataPoints that are selected in the ZoomRectangle ?
Kanika
Hi ,
Can Somebody please help me with this ..
Hello Kanika,
Currently, the XamWebChart control doesn't support this kind of functionality. We would appreciate if you give us your feedback on this new feature request here and we will try to include it in future releases
Is there some work around.
Can you tell me what is the logic behind translating locations between 0 to 1 in a graph, that may help to find a temporary work around
It depends on the width/height of the graph, axis scale/scroll, internally calculated minimum and maximum. It is internal chart logic.
In your case you might try going through the visual tree of the chart and find the current visible data points.
