I applied filter settings on XamGrid(10.3), 'FilterRowTop' and 'FilterRowBottom' works fine, but FilterMenu option is not doing anything.
Please help me if i am missing anything from below. I am using binding to set the "AllowFiltering" property. Following code will set the binded property,
case "Filter Top":((ExportHelper) exportHelper).GetFilterLocation = FilterUIType.FilterRowTop;break;
case "Filter Bottom":((ExportHelper)exportHelper).GetFilterLocation = FilterUIType.FilterRowBottom;break;
case "Filter Menu":((ExportHelper)exportHelper).GetFilterLocation = FilterUIType.FilterMenu;break;
case "Disable Filter":((ExportHelper)exportHelper).GetFilterLocation = FilterUIType.None;break;
We have a sample that does exactly that:
https://www.infragistics.com/samples/silverlight/grid/#/filtering-data
Have you taken a look at it?
-SteveZ
