I am having a problem with webdatechooser control.
I am using the webdatechooser control in the an expandable panel. Now whenever I open the webdatechooser control's calendar to choose a date , it kinda overlaps two button controls which are placed below that control. Now , when I shrink/expand the webpanel after choosing the date , the buttons are moving up and down as desired but the images which are included in that are still staying at the same place and I have to click on those images to get back to them within the shifted buttons.
Again this is happening only when the webdatechooser control is used to choose a date from the calendar. This problem is not happening if I dont expand the calendar control and enter the date manually.I am attaching the screenshot for better understanding the problem.
As a workaround, I added the postback in the aftercloseup property of WebDateChooser control. That solves the problem but its definitely not a desirable solution since we dont want unnecessary postbacks.
Please suggest me how to tackle this problem without postback.
I request the Infragistics team to provide some help regarding this issue.
Read this post, on how to get IG help: https://www.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/24172/limited-shortcut-key-combinations-for-windows-forms-ultratoolbarmanager#24172
Thanks Edward for pointing me to the Developer support site.
However , I was thinking that it might be fixed with using any of the already exsiting infragistics properties for the WebDateChooser control.
jyrsi said: Thanks Edward for pointing me to the Developer support site. However , I was thinking that it might be fixed with using any of the already exsiting infragistics properties
The page I sent you to is for exactly that.
