I have an issue about catching some events from a DataGrid outside a warp.
While the warp works, it is fine (except rare cases). But after I do a javascript
warp.setTimer(0);
thanks to a server side
Infragistics.WebUI.Shared.CallBackManager.AddScriptBlock(this, warp, "WARP_Stop();");
, if I trigger the events, I only have a PostBack which doesn't trigger anything.
Is it due to the use of the IG callBackManager ? How should I proceed to stop and start the warp properly then ?
Thanks in advance if a warp specialist can help me.
Vince
Hi c21Vince,
try to replace WARP with UpdatePanel and disable grid's AJAX, WARP is designed for UltraWebGrid.
